After upgrading to discourse 1.3 I can’t edit the category descritpion.
Is this an expected behavior ?
Your image doesn’t seem to be rendering.
thanks. I have updated my previous post.
What actually happens when you click that button? It should take you to the Description topic.
It is working on my instance, but to be fair I’m running v1.4.0.beta1
Yes, It take me to the About topic. But the content is not the same as the short description on my previous screen shot.
I’m jealous. I’m testing with v1.3.0.beta11 +51 and I just fetched Master a short while ago.
I don’t even have a “description” button. The new Category gets created with the boilerplate About “edit this post”
I have just upgraded my version to v1.3.0.beta11 +51
the previous one was a v1.2.xxxx
The category description is the first paragraph (¶) of the topic it takes you to.
Edting and saving the topic solved my problem. Not sure why the description and the related topic where out of sync.
