Just installed this. It looks like only admins can move the cards, is there a way to change it so users can also move them, or to set the user level required to move a card?
Are you using category mode or tags mode? If it’s tags, search for ‘min trust level to tag topics’ in your forum settings.
I think there’s a similar setting for “min level allowed to recategorize topics”
You can try manually promoting a user to trust level 3, that should also give them the required permissions.
yes, that’s it thanks. although ours is set to 0:New User.
i suppose that makes sense as a user can create a tag, they just can’t edit tags of others posts which is needed when they are dragging a task to another column.
must be something else causing it. i’m going to experiment with ‘assigned’. maybe the user hadn’t assigned the card to themselves and if they did that would solve it
no, that didn’t fix it. let me turn off all other plugins and components and see if there’s a conflict
that got it. i’d rather it was level 1 or 2 and higher, but unless i can edit that or create new higher trust levels i’ll just have to promote all users to level 3 for the time-being.
thanks for your help @ssvenn
