Kunnen we wiki's uitsluiten van onbeantwoorde onderwerpen?
The discussion revolves around excluding wikis from unanswered topics. rachel-statsnz initially asked if it’s possible to have the unanswred button exclude wiki-type posts. matenauta suggested adding a selector to hide certain categories and tags.
However, Canapin explained that wikis are a post-level attribute and cannot be excluded from topic lists as they are not a topic-level attribute. matenauta and Canapin agreed that using tags might be the best approach.
ToddZ provided an alternative solution, suggesting that posting a reply, such as inviting people to edit the wiki, before locking the topic can exclude it from the Unanswered list.
Is there a way to have the unanswered button exclude wiki type posts?
Could be better to add a selector for hide some categories and tags.
We have a glossary wiki sub-category that should to be outside the filter too :slight_smile:
Thanks! Can you explain how to do that? :grimacing: I’m a bit technically challenged…I am assuming it is this box below but for some reason it is not excluding those categories?
u
Wikis are a post-level attribute, and the topic lists only have access to topic-level attributes, so it’s impossible to exclude wikis since we can’t know if a topic is a wiki or not in topics list pages.
So the best approach you see here should be using tags?
I believe so. :slight_smile:
I opened a topic a while ago about the wiki identification from the topic list, where I got this info.
@rachel-statsnz – The settings you’re looking at there specify pages where the Unanswered link won’t be shown in the menu – not pages to exclude from Unanswered status.
When I set this up, I also wanted to exclude certain informational topics from the Unanswered list. My workaround is to post one reply, e.g. “This informational topic is not open for comments.” – before locking the topic. For your wiki topics, a comment inviting people to edit the wiki would serve to exclude the topic from Unanswered.
