Filtering for unanswered posts
The discussion revolves around implementing a quick filter for unanswered posts on a Discourse forum. etarena followed a solution provided by tshenry, but encountered issues with the “Unanswered” button not appearing on the top-level URL. tshenry mentioned that the component is being improved and suggested checking theme settings, but etarena still experienced erratic behavior.
tshenry advised waiting for the updates, which are currently in progress. The core change is in place, and a dropdown version of the component is almost working perfectly, but some routing edge cases need to be ironed out tshenry. etarena expressed appreciation for the update, and 401Ott inquired about the feature’s status.
I am an admin for a discourse forum: https://forum.image.sc/ and we are having issues with implementing a feature to add a quick filter for unanswered posts. I followed the solution provided here by @tshenry:
However, we noticed that the Unanswered button does not appear when accessing the top-level https://forum.image.sc URL. But when navigating to any other page, e.g. https://forum.image.sc/latest , then it appears again. We aren’t sure what might be wrong here… as we followed the installation instructions.
Any thoughts on this would be much appreciated…
Just a heads up - we’ve been looking at improving this component. There is some unexpected behavior in certain scenarios as it stands that will require a change in core before we can update the component. In addition to fixing some buggy behavior, the plan is to move it to a drop down toggle that’s similar to the category/tag drop you would find on topic lists.
If you still want to use it right away, I would check your the theme settings for the component. If there is a / listed in the exclusions list, try removing it.
@tshenry
Thank you for your response. I appreciate it.
I tried what you suggested with removing the / listed in exclusions list… it still resulted in similar erratic behavior. ?? And then we also lost the ‘Unread’ filter - which also seems to disappear/reappear ‘randomly’ when clicking different filters…
I suppose waiting for the updates is best at this point?
Yes please :slight_smile:
This sounds like a great feature. I was curious if Discourse was updated to have unsanswered as a dropdown?
Thank you in advance
The core change is in place and I have the dropdown version of the component almost working perfectly, but there are a few routing edge cases that I’d like to try to iron out. I’ll be sure to post an update on this topic as soon as it’s ready.
Thanks for the update @tshenry !!! Great news!!! :slight_smile:
