Cannot remove assignment note
In the “Bug” category under the assign tag, andresfromsonar reports an issue where assignment notes cannot be removed once added. While assignments can initially be created with or without a note, editing an existing assignment triggers a whisper-style interface. Since Discourse prevents saving empty whispers, users are unable to clear the text and return the assignment to its “no note” state.
The user argues that an empty assignment note is a valid state, making this limitation illogical for this specific feature. They also reject deleting the entire assignment entry as a workaround, as this removes the history of the assignment action and leaves the topic assigned.
You can assign a topic without writing a note:
Or you can assign it with a note:
You can edit the note later, and it pops up as if you’re editing a whisper. It doesn’t let you save an empty whisper, therefore, effectively, you cannot remove the note:
I understand that for a normal whisper this makes sense: if you want to empty a whisper, just delete it! But in this case it does make sense to want to empty the assignment note. After all, “empty assignment note” is a valid state for an assignment entry (as seen in the 1st screenshot). But it’s not a state that you can return to via editing.
Deleting the assignment entry is not a good workaround. You’re losing track of the assignment action. The topic remains assigned even if this entry is deleted.
