Cannot use zoom for lightbox images on phones
Users discuss the inability to zoom images in the lightbox on mobile devices, particularly on Android. lucas_maximus reports the issue, and codinghorror demonstrates that zooming works on their device, leading to a discussion about the user-scalable=no meta tag causing the problem. cpradio identifies the meta tag as the culprit and suggests a fix by changing its settings. Lid proposes a JavaScript solution to dynamically adjust the viewport meta tag only when the lightbox is open, which would enable zooming without affecting other pages. solhuebner and cpradio emphasize the need for a user-friendly solution that doesn’t require changing browser settings. Luisa_V shares a CSS workaround using touch-action: unset. The discussion concludes with a call for a PR to implement a lightbox-specific fix, though some users prefer a broader solution.
If a image is resized to smaller dimensions in discourse I cannot zoom the image either when it is in the lightbox or in the actual thread.
This makes viewing larger images that have been linked difficult without browsing away from the forum.
1 « J'aime »
Zoom would be a dream in the lightbox!
I am 99% sure you can do it on G+
Let’s try a large image here and see:
1 « J'aime »
Galaxy Note 3 4.4.2 with Chrome… Can not zoom…
And I can move the site a very little bit too the left…
No repro.. here’s me after tapping on the lightboxed image on Chrome latest, Android latest.. then using my two fingers to pinch it bigger
If I tap once on the lightbox it zooms in bit at a fixed ratio and then i can only scroll but not zoom…
1 « J'aime »
Just tried it, if I tap in Chrome on Android I can zoom but only the top left hand corner when tapping. I am using latest Chrome on Android 4.1.2 on a S3 mini.
EDIT: it is totally broken in Firefox for Android.
are you sure you were able to use pinch gesture to control zoom after tap? i think it is a good bug if yes :smile:
I opened this topic while ago
https://meta.discourse.org/t/add-pinch-to-zoom-for-images-on-mobile/19152
I cannot zoom using Chrome on Android.
That is odd, considering I showed screenshots, above, of me zooming an image in Chrome on Android.
Do you have “force enable zoom” turned on under accessibility in chrome’s settings?
2 « J'aime »
I have it disabled, if I enable it I can zoom
You should not be forced to use “force enable zoom” because how should I educate my users to do that…?!
2 « J'aime »
I can do zoom in on Windows Phone but I suspect it’s just a happy accident… I can also zoom out from the page.
AHA! Indeed I do. Sorry about that!
As an FYI, it seems to be because of this meta tag
<meta name="viewport" content="width=device-width, minimum-scale=1.0, maximum-scale=1.0, user-scalable=no">
If you set it to
<meta name="viewport" content="width=device-width, initial-scale=1.0">
You get the same initial output and permit users to pinch and zoom.
3 « J'aime »
Looks like a good solution to me. Would a PR be accepted for that?
Unlikely since that affects every single page. You need a solution that affects light box only.
