Can't access site after installation
I installed Discourse per the instructions on github on a box with Ubuntu 15.04. Everything executed successfully however I did not purchase a domain name so I put my IP in the hostname field. Even after getting a success message when running “/.launcher start app” the IP refuses my connection. I’m worndering if it is okay for me to have used my IP as the hostname or if it must be different? I am perfectly happy with navigating to an IP rather than domain name.
Did you get this figured out?
If you’re getting a connection refused message then it’s more likely a problem with the port not being accessible from wherever you are.
You could check from a command line with
 telnet ipnumber 80
If it works from the but not elsewhere it’s a problem with port mapping and firewall stuff.
When I run that I get:
root@ITRGAVAPOC011:~# telnet ipnumber 80
telnet: could not resolve ipnumber/80: No address associated with hostname
When bootstrapping/installing via Docker does it not bind to the port
automatically?
It looks like you didn’t replace ipnumber with the actual IP-number of your discourse install. :wink:
And if it “works” it’ll look like nothing is happening. You can then type
 get /
And see some stuff that likely looks like gibberish. Then you’ll need to know that control-[ and then q enter will quit telnet. I think that’s it.
So I tried it with the actual IP and no luck, connection refused. Tried looking at IP tables but don’t see any blocking rules. (blocked out my domain). Would I need to create a new rule to allow port 80 specifically?
You can try
netstat -atn
To check for open ports.
Maybe you didn’t expose the port in the config file?
Is there a separate config file just for Discourse to set up the ports?
Did you follow these instructions?
I did, I’m wondering if it’s because I installed in a corporate lab setting. I did have to add proxies to the app.yml file to be able to reach out to the internet and install. Might be tied to that somehow.
Yep, the proxies are probably what’s going on. The installation is properly listening on 80/443, but the outside world can’t get that far.
