Can't access Vultr DNS
Hi everyone,
I’ve chosen Vultr to host a server on which i’ve installed Discourse.
The problem is : i can’t access my forum by typing “discourse.cinefilons.com” (HOSTNAME) in the address bar. The only way i can access my forum is by typing the IP address of the server.
I know i failed somewhere but i don’t know where, i’m kind of a noobie… could anyone help me please ? Thanks!
PS : sorry if my english is bad, i usually speak french.
Did you remember to create a dns entry for your subdomain and point it to the server?
Apparently cinefilons.com isn’t a registered domain name. You’ll need to register it. Go to your registrar (if they’ll be managing your DNS) and direct the IP to your server.
i created a domain after the installation of Discourse on my server. Is it a problem ?
Did you actually register the domain name at a registrar? The domain name appears to still be available to register if it is indeed cinefilons.com
Could you give some examples of “registrar” plz ? Is Vultr a registrar ?
Vult ir a server provider. A registrar would be like domains.google.com, godaddy.com, namecheap.com
Ok i see much clearer now. Thank you !
I live in Belgium. Most of the members of my forum will come from France or Belgium. So it’s more logical for me to take “domain.be” than a “domain.com” right ? I mean what’s the difference between the two of them ?
No real difference. .com’s are usually the most desirable but that’s entirely up to you.
Since you’re in Belgium I would recommend you use Cloud Computing & Hébergement Web | OVHcloud France or https://www.gandi.net/ as your registrar. They have better price for Europeans :wink:
Thank you mate ! They do offer better price indeed :slight_smile:
