After updating to the latest version I can not add a link to the flyer. In the preview appears the image, but can not save. It produces an error “Flair URL”. For my part, there should not be any problems. I can not even update the name of the group in which everything worked before the update.
Do you see any error when you visit the logs at /logs? What is the URL you’re trying to use?
I had a similar problem recently when I tried to use a path without http://hostname for the flair URL. Apparently, it really wants a URL.
Thank you. After adding http://hostname to the link it’s work fine.
