Can't delete badge if a user has it as their title badge
The problem is that a badge cannot be deleted if a user has it as their title badge. pfaffman encountered this issue and received a 500 error with a PG::ForeignKeyViolation error message when trying to delete the badge. RGJ pointed out that the error occurs because the badge ID is still referenced in the user_profiles table.
To resolve the issue, pfaffman deleted the referencing rows in the user_profiles table, allowing the badge to be deleted. However, RGJ warned that this approach deleted the profiles of two users and recommended updating the granted_title_badge_id instead.
RGJ and pfaffman agreed that the issue is a UX bug, as the user interface allows the deletion of a badge even if it’s referenced in another table, and returns a 500 error without explanation. The correct behavior would be to prevent the deletion of the badge through the user interface to maintain referential integrity.
I guess this is another corrupt table issue? Though this is on an instance where it is unlikely that the database was shut down uncleanly.
I created and deleted a badge with no members and that worked fine. I added a user to a new badge and deleted it and that worked fine.
Started DELETE "/admin/badges/118" for 71.89.242.121 at 2020-05-28 16:50:04 +0000
Processing by Admin::BadgesController#destroy as */*
  Parameters: {"id"=>"118"}
  Rendering text template
  Rendered text template (Duration: 0.0ms | Allocations: 1)
Completed 500 Internal Server Error in 304ms (ActiveRecord: 0.0ms | Allocations: 114838)
ActiveRecord::InvalidForeignKey (PG::ForeignKeyViolation: ERROR:  update or delete on table "badges" violates foreign key constraint "fk_rails_38ea484ed4" on table "user_profiles"
DETAIL:  Key (id)=(118) is still referenced from table "user_profiles".
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.1/lib/patches/db/pg.rb:72:in `exec_params'
Failed to handle exception in exception app middleware : PG::ForeignKeyViolation: ERROR:  update or delete on table "badges" violates foreign key constraint "fk_rails_38ea484ed4" on table "user_profiles"
But I don’t quite know where to look or what index to try to rebuild.
TABLE "user_profiles" CONSTRAINT "fk_rails_38ea484ed4" FOREIGN KEY (granted_title_badge_id) REFERENCES badges(id)
What does SELECT * FROM user_profiles where granted_title_badge_id = 118; tell you?
That gives me two users.
Then I
delete  FROM user_profiles where granted_title_badge_id = 118;
and then I could delete the badge.
My problem appears to be solved, at least for this badge.
But shouldn’t deleting the badge do this? Now it seems more like a :bug:
:scream: you’ve just deleted the profiles of two users :scream:
Next time
UPDATE user_profiles SET granted_title_badge_id = (another id) WHERE granted_title_badge_id = 118
Oh. My. That does seem like a problem. This is why I tell people not to make db changes in sql.
At least it was only 2 users. Maybe I can still scroll to see who they were.
But it still seems like a bug that you can’t delete a badge if someone has it.
Recategorizing as a bug.
No. It seems like a (minor) bug that you can initiate the deletion of a badge if someone has it. It would be nicer if the user interface would prevent it. It is totally correct that the database prevents deletion and preserves referential integrity.
Agreed that it’s better to not delete the badge than leave the system in a broken state, but right now it returns a 500 error with no explanation.
A minor UX bug, sure, but it keeps someone who doesn’t know as much as you do from being able to delete a badge. :slight_smile:
Thanks very much for your help. I’m waiting to see what happens to those users whose profiles I deleted!
