לא ניתן לטעון את האתר בספארי
Hi everyone. Sorry for my silly question :sob:
I set up discourse at the subdomain name www.pila.cc. I use a CNAME record and redirect pila.cc to www.pila.cc. Here are all the records:
I can’t load my site in Safari. The page keeps showing loading. However, it opens in Chrome. After opening the website in Chrome, I can also open it using Safari.
I guess this is a problem with DNS parsing. Is it because I added CNAME records to the naked domain? If so, is there any way to redirect www.pila.cc to pila.cc without the CNAME?
Sorry for my poor expression, because I’m not a native English speaker
Hi, welcome!
This is a little confusing on what you really want to do.
If you want to redirect www.pila.ccpila.cc, I believe it would make sense to do this way:
@     A        8.219.210.255
www   CNAME    pila.cc.
I’m sorry that I made a typo. I want to redirect pila.cc to www.pila.cc, since the discourse is set up at www.pila.cc, and I hope users can also open the forum when entering pila.cc.
Still waiting for help :sob:
It says: “Safari browser cannot open this page because it is unable to establish a secure connection with the server.”
I’m not getting this error.
However, I do see an error running this online SSL certificate check:
Certificate name mismatch
I believe that’s because the certificate only covers www.pila.cc.
Thank you for your reply! How can I add certificate for the naked domain pila.cc?
I think it depends on your SSL certificate provider. For Let’s Encrypt these instructions ought to do the trick:
Thank you for the advice!
I am using Let’s Encrypt. I will try to update app.yml late tonight in my timezone.
