Can't restore a 20GB backup on a 60GB Digital Ocean instance (fresh Discourse install)
סיכום מבוסס בינה מלאכותית
The original poster, meglio, was unable to restore a ~20GB backup on a 60GB DigitalOcean instance due to the disk becoming 100% full. The issue occurred because Discourse copies the backup file to /tmp and then unzips it, effectively tripling the original size.
codinghorror and sam suggested doing a database-only restore and then manually copying the files, which meglio found to be a successful solution.
Additionally, sam noted that the CREATE INDEX step can take a long time, and suggested increasing db_shared_buffers to speed it up.
ljpp offered an alternative solution of temporarily increasing the droplet size to complete the restore, then scaling back afterwards.
So, I have a ~20GB backup.
When I try to restore it in a fresh Discourse install on a 60GB DigitalOcean droplet, the UI freezes, and it ends up with the following situation:
df -h
udev            2.0G     0  2.0G   0% /dev
tmpfs           396M   26M  370M   7% /run
/dev/vda1        58G   58G     0 100% /
tmpfs           2.0G     0  2.0G   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           2.0G     0  2.0G   0% /sys/fs/cgroup
/dev/vda15      105M  3.4M  102M   4% /boot/efi
/dev/sda1       246G   25G  209G  11% /mnt/volume-fra1-01-part1
overlay          58G   58G     0 100% /var/lib/docker/overlay2/1b169d3fb316ed26072c13336a9b260add686b548d856f4765560637907b4efd/merged
shm              64M  4.0K   64M   1% /var/lib/docker/containers/37cfaddc5a5466550d7e0471b16b70a5a7b0659dfb7f3e8753dabb0b6d885127/shm
tmpfs           396M     0  396M   0% /run/user/0
The UI stuck at “CREATE INDEX…”.
My guess:
I remember Discourse first copying the backup file to the guest’s /tmp, then unzipping it, which literally means +20GB +20GB = +40GB files
Should not the backup file be unzipped somewhere in the backups folder directly (without copying to /tmp), as the backups folder can be mounted to a bigger drive. Also, what is the idea behind copying the backup file before unzipping it?
Maybe you should try a database only backup, then you can copy all the images over in a different manual step? Since most of the size in the backup is the images.
I would first follow @codinghorror recommendation here and do a restore of database only and copy files by hand.
Additionally, for meta when I restored it sat for about 30 minutes on CREATE INDEX, you are just going to have to wait it out. To speed it up somewhat you could increase: db_shared_buffers per:
Did so and it worked. Thanks Jeff and Sam for your input.
Yep, I realise, but it wasn’t the case. The disk got full 100% – I think because of the manipulation with the backup file (copying, then unzipping, so effectively tripling the original backup size).
Alternative solution would have been increase your droplet size temporarily, scaling back when the job is done.
