Hi @kraml I made it works in my sandbox server, but when i try the same thing in my production server I have the bootstrap error, and I have my docker working in a partition FSType 1 is mounted fine and I did the steps you mencioned
Stop the service
Mount the var/lib/docker in the partition
restart the daemon
start the service (all fine)
go to /var/discourse
launch the bootstrap and have the same error
Any advice?
kraml
(Kai Liu)
2017 年5 月 10 日 04:15
62
The log you copied in screenshot don’t help in diagnose the problem, you need to provide the full rebuild log.
It is high probable that one of your plugin caused the rebuild problem, if you are sure you have done the right steps regarding filesystem.
The final step was rename folder /var/discourse, and make a new install, good luck i have a backup and now my site is up and with all the data.
naomi
2017 年7 月 6 日 06:49
65
thanks! I can confirm that this works great on a Linode running Ubuntu 14.04. Note that I was not able to actually stop the app because of the launcher storage driver error message.
nukeador
(Nukeador)
2017 年7 月 6 日 12:17
66
This seems to be the only thing that worked on my Ubuntu 16.04, thanks!
In a similar situation (Debian 8 Jessie)
“Your Docker installation is not using a supported storage driver”
Docker info
Storage Driver: devicemapper
# cat /etc/debian_version
8.9
# dpkg --get-selections | grep linux-image
linux-image-3.16.0-4-amd64 install
linux-image-amd64 install
# dpkg -L linux-image-3.16.0-4-amd64 | grep aufs
/lib/modules/3.16.0-4-amd64/kernel/fs/aufs
/lib/modules/3.16.0-4-amd64/kernel/fs/aufs/aufs.ko
Solution was to create new file: /etc/docker/daemon.json
"storage-driver": "aufs"
service docker restart
cyborg
(Cy)
2017 年10 月 8 日 09:59
68
This basically saved my life. Worked like a charm in my EC2 Linux instance and relived it.
jandres
(Julian)
2018 年6 月 1 日 15:28
69
According with:
For Ubuntu 14.04 version, you must install linux-image-extra-* package before install docker.
So if you already installed docker, you should uninstall it first before start to install linux-image-extra-* package.
sudo apt-get purge docker-ce
sudo rm -rf /var/lib/docker
sudo rm /etc/systemd/system/docker.service
Then install linux-image-extra-*
sudo apt-get update
sudo apt-get install \
linux-image-extra-$(uname -r) \
linux-image-extra-virtual
and finally reinstall docker from git
wget -qO- https://get.docker.com/ | sh
regards
Lilcheo
(Cheo Nia)
2019 年7 月 3 日 07:49
70
我找到了一个修复方法,如果仍然不起作用,请执行以下命令:cp /etc/systemd/system/docker.service /lib/systemd/system/docker.service。这解决了我的问题。
你好,
我尝试了 @mpalmer 的解决方案,但无法重新构建。
运行 docker info | grep Storage 后,我得到以下输出:
警告:不支持交换分区限制
警告:aufs 存储驱动已弃用,将在未来版本中移除。
无论如何,当我尝试重新构建时,系统显示:
您的 Docker 安装未使用受支持的存储驱动。如果我们继续操作,可能会导致安装损坏。
推荐使用 aufs 存储驱动,但 zfs/btrfs/overlay 和 overlay2 也可能有效。
已知其他存储驱动存在兼容性问题。
您可以通过运行 “docker info” 并查看“存储驱动”(Storage Driver)一行来确认当前使用的文件系统。
> ps ax |grep dockerd
864 ? Ssl 0:00 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock -s aufs
1664 pts/0 S+ 0:00 grep --color=auto dockerd
> cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION=“Ubuntu 18.04.3 LTS”
我遗漏了什么?
Falco
(Falco)
2019 年8 月 26 日 18:22
72
请更新启动器:
cd /var/discourse
git pull
之后您就可以重新构建。
