Impossibile aggiornare: "Docker Manager: IMPOSSIBILE AGGIORNARE"
Sto cercando di aggiornare Discourse perché sono sommerso dallo spam. Quando clicco per aggiornare il gestore Docker, ricevo prima questo errore:
Failed upgrade:
precompile target: footnote_rtl
precompile target: poll_rtl
precompile target: spoiler-alert_rtl
precompile target: chat_mobile_rtl
precompile target: discourse-gamification_mobile_rtl
precompile target: discourse-solved_mobile_rtl
precompile target: discourse-topic-voting_mobile_rtl
precompile target: chat_desktop_rtl
precompile target: discourse-gamification_desktop_rtl
precompile target: discourse-topic-voting_desktop_rtl
precompile target: poll_desktop_rtl
precompile target: desktop_theme Dark Mode
precompile target: desktop_theme Sidebar Theme Toggle
precompile target: desktop_theme discourse-right-sidebar-blocks
precompile target: mobile_theme Dark Mode
precompile target: mobile_theme Sidebar Theme Toggle
precompile target: color_definitions Dark Mode (LC-Dark)
precompile target: color_definitions Dark Mode (Base)
precompile target: desktop_theme Default
precompile target: mobile_theme Default
precompile target: color_definitions Default (LC-Light)
precompile target: color_definitions Default (Base)
Done compiling CSS: 2024-07-26 02:45:47 UTC
/var/www/discourse/lib/discourse_ip_info.rb:48:in `mmdb_download': undefined method `path' for nil:NilClass (NoMethodError)
    filename = File.basename(gz_file.path)
	from /var/www/discourse/lib/tasks/maxminddb.rake:67:in `block (3 levels) in <main>'
	from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `each'
	from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `block (2 levels) in <main>'
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:210:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:111:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/runner/runner_command.rb:43:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor.rb:527:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/command/base.rb:87:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands.rb:18:in `<main>'
/internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:38:in `require'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Spinning up 7 Unicorn worker(s) that were stopped initially
Non accedo da un mese né all’admin né al server, quindi non è cambiato nulla. Non sono sicuro di cosa indichi il log degli errori.
Sembra un problema con il tuo maxmind. La ricostruzione dalla riga di comando aiuta?
2 Mi Piace
