מצטער, הייתה שגיאה בשדרוג Discourse. אבל אז Discourse מציג שהמודול מעודכן
סיכום מבוסס בינה מלאכותית
@kgreed is experiencing an issue with upgrading Discourse modules. After clicking the upgrade link, they received a “Sorry, there was an error upgrading Discourse” message, but the modules are now showing as up to date. However, the Discourse version still indicates that an upgrade is needed.
@kgreed shared the output of the last update, which shows a RuntimeError and a Killed message, indicating that the upgrade process failed. Despite this, the modules are now up to date, and kgreed is unsure if they should believe this or investigate further.
@kgreed plans to check a related issue on the Discourse meta forum for a possible solution.
For the docker_manager and discourse-solved modules I clicked the upgrade link in Discourse and after some time received the Sorry message.
However the modules now show as up to date in my Discourse.
Do I believe that or should I be running something in Linux? ( is so, what?)
I ran the last update and got ouput
296913.235374078 Compressing: application-c6861fce930ebb07ae1f5a622066ef6a21c3e3daaa3a134ab5a008ef5c22468a.js
uglifyjs '/var/www/discourse/public/assets/_application-c6861fce930ebb07ae1f5a622066ef6a21c3e3daaa3a134ab5a008ef5c22468a.js' -m -c -o '/var/www/discourse/public/assets/application-c6861fce930ebb07ae1f5a622066ef6a21c3e3daaa3a134ab5a008ef5c22468a.js' --source-map "base='/var/www/discourse/public/assets',root='/assets',url='/assets/application-c6861fce930ebb07ae1f5a622066ef6a21c3e3daaa3a134ab5a008ef5c22468a.js.map'"
Killed
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:178:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:86:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.8/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:59:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/commands/runner/runner_command.rb:42:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/command/base.rb:69:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/command.rb:46:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/commands.rb:18:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.8/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.8/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.8/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.8/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.8/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.3/lib/active_support/dependencies.rb:324:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.3/lib/active_support/dependencies.rb:291:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.3/lib/active_support/dependencies.rb:324:in `require'
bin/rails:17:in `<main>'
Spinning up 3 Unicorn worker(s) that were stopped initially
Now everything shows as up to date
Yet the Discourse version still indicates I need to upgrade
I will check this Error: ENOENT: no such file or directory on upgrading - #19 by bts
