Can't upload PDF to S3
Trying to upload PDF’s I have followed all the posts here on how to do it and nothing works - always blocked even if smaller than limit size set. I have added ‘pdf’ to the allowed file suffixes list. Consequently created an AWS Free Tier S3 account and a backet. Nothing uploads to S3, not even images.
I appear to be hopelessly lost. Any pointers as to why using S3 with proper access keys wont work?
Self hosted Docker install.
So it’s not a PDF issue, but an S3 issue. DId you follow Using Object Storage for Uploads (S3 & Clones) or Setting up file and image uploads to S3?
So I spent the time learning the details of Amazon S3, Cloudfront and so on. I am happy to report it uploads great!
But still totally unable to upload any PDF. I can’t quite see how this could be S3 related given that other files work fine - but I may be wrong.
No matter what size I set for file uploads and no matter what size a PDF is, I can’t upload them. I always get:
Sorry, that file is too big (maximum size is 40 MB). Why not upload your large file to a cloud sharing service, then paste the link?
I followed the instructions for how to increase file upload size but no size PDF will upload, includng sizes well below the limit. I am on the absolutely most update commit set of Discourse.
Finally figured it out at last. I had to add client_max_body_size in the nginx reverse proxy server for discourse. In hindsight this is obvious, but it takes time to see sometimes!
Good catch! So obvious… once you know. Stuff like that is hard to figure out and why standard installations are (mostly) so that’s supported here.
