Good morning,
Having a file upload issue that I just can’t seem to figure out.
I am running the discourse instance via docker in a VM on Google Cloud.
I currently have file uploads and discourse backups using S3 via GCS enabled and those functions are working properly after following the instructions on the Configure an S3 compatible object storage provider for uploads thread. I can see the uploads in the bucket and when I look at upload URLs, all uploads are showing the proper URL from the CDN so they seem like they are pulling correctly from the bucket.
I then followed the instructions on the Change the maximum attachment/upload size thread and I have the following in app.yml under params
params:
db_shared_buffers: "1024MB"
#db_work_mem: "40MB"
#version: tests-passed
## Maximum upload size (default: 10m)
upload size: 1000m
I then went to Settings>Files and entered the following:
But when I go and upload a 12.5MB PDF to a post, I receive this:
The other two PDFs that are 6-7MB uploaded fine and were uploaded through the S3 bucket as intended and returning with CDN addresses. So I’m pretty stumped and any help would be much appreciated. Thanks in advance.
