Catagories wont load
Howdy
I just upgraded to 2.6.0.beta1 docker version, and now categories wont load initially. I get the following in the dev console.
This happens in any of the categories. If I click on the category selector, when it drops down, the page will load correctly behind it.
Any suggestions how to start debugging this?
Thanks
-=Bob
try in safe mode, looks like the events plugin you are running is not compatible.
Ayep, thanks. Should have actually read the error message in the console. Thanks. Back to working now that I removed it from the app.yml
