I feel that the ‘Latest posts’ homepage is perfect for conversations just as Discourse itself encourages.
But for the first time visitor (not-logged-in users), a ‘Categories & Latest posts’ gives a better idea of what the forum is about, as the ‘Categories’ section can define really well what you can expect there, while also having a peek at the ‘Latest posts’ on the forum.
This could also have some SEO implications as the search engines will crawl the ‘Categories & Latest posts’ homepage, which you can control a bit better in terms of keywords, text on page through the ‘Categories’ section. Also, the categories/sub-categories are linked directly from the homepage (better link flowing).
This could be the best of both worlds.
3 « J'aime »
Last I knew, categories were linked directly from the Latest page. If this is not the case for you, have you checked any plugins / modifications you might be using to make sure they didn’t break this?
True, the categories for those posts appearing as ‘Latest posts’ are being linked in the ‘Category’ column, but that’s not the point I was trying to make, but rather that the ‘Categories & Latest posts’ front page might be more suitable for visitors & possibly search engines and vice-versa (‘Latest posts’ is more suitable for already registered users).
So, my question is whether others feel the same and if such an ability to set different front pages is practical or not ?
1 « J'aime »
I’m too lazy busy to find it now, but there has been discussion about having member selectable “home” pages.
If that can happen it would be easy enough to have a default home page and let members decide for themselves which they prefer. IMHO, that would be better than having code make a decision for them.
1 « J'aime »
It’s not even that, but just 2 homepages that already exist in Discourse. The difference would be to serve one for users, and one for visitors (not-logged-in) for the above mentioned reasons.
I guess I’m not understanding what you’re getting at. AFAIK, it is exactly that. The default of all the possible home pages will display for not-logged-in visitors, and once logged in, members would (when / if it happens) be able to choose another if they wanted to.
I agree, having a landing page with categories and latest posts is better for new users to understand the community.
Looks like this has been discussed a long time back, is there a way this has been enabled?
C’est aussi quelque chose qui m’intéresse : l’idée initiale d’avoir une page d’accueil distincte configurée par l’administrateur selon que l’utilisateur est un visiteur ou connecté, et non la suggestion ultérieure d’une préférence utilisateur.
- Un visiteur ou un robot d’indexation arrive sur le forum et voit la liste principale des catégories (éventuellement accompagnée des publications à la une, les plus récentes ou les plus populaires), ce qui lui donne une vue d’ensemble immédiate du sujet du forum, des catégories actives ou populaires, et de la direction à prendre ensuite.
- Un utilisateur connecté arrive sur le forum (déjà familier avec les catégories) et voit les publications les plus récentes, ce qui lui permet de suivre ou de reprendre rapidement les conversations dans toutes les catégories.
Chaque page d’accueil répond au cas d’usage préféré de son public cible, mais se fait au détriment de l’autre. Les visiteurs ne sont pas encore orientés, aussi un flux en direct des publications récentes ne donne pas beaucoup d’informations sur la structure de la communauté. Les utilisateurs connectés connaissent déjà les catégories, donc la page des catégories distrait de la question « qu’est-ce qui s’est passé depuis ma dernière visite ? ».
Utiliser « Catégories + Publications à la une / Récentes / Populaires » pour les deux publics répond plus ou moins au besoin, mais cela ajoute toujours du bruit visuel pour les utilisateurs connectés qui disposent déjà d’un sélecteur de catégories sous forme de menu déroulant (et qui est fortement mis en avant dans la colonne « principale » la plus à gauche).
