Categories Layout Override
Normally the desktop categories page layout is set via a global site setting. When added to a theme, this component will allow you to override the layout of the categories page for that specific theme.
Installation
Repository Link
https://github.com/tshenry/discourse-categories-layout-override
This component can be installed more than once if necessary. If you do this, it is recommended to modify the name so you can keep track of which layout is associated with each copy of the component.
If you are unfamiliar with theme components and how to install them, check out the theme installation guide . And if you’d like to learn more about Discourse themes, take a look at this guide .
Cool, thanks for sharing this
Recently with ver 3.2.0.beta 4-dev theme component was not working. I also hope that mobile display customization will be integrated into the core of discourse. Because I want a synchronous experience from desktop to mobile
Thank you for the report @hoangphuctran93! The component should be fixed now with the following commit:
https://github.com/tshenry/discourse-categories-layout-override/commit/1726313ed4e9e3369b97b8dd0c7f72c5c4211d5f
Please go ahead and update the component from your admin dashboard when you have an opportunity.
Is there a way to use this categories layout override for the mobile categories display layout?
