Verschillende categoriepagina-stijl voor een specifieke groep
Curious.
Is it possible to force a different category page style setting for a specific group or primary group?
It should be possible with a theme component, but as far as I know no one’s built one.
There is a theme component available that makes it possible to use a different category page layout for a specific theme… and it seems possible to use this as a starting point to build a component that can do the same based on group membership.
Hi @awesomerobot!
Thanks a lot for your help. I really appreciate this.
After installing this theme, I can possibly use this guide of yours here to assign this specific theme with the added component, right?
@falco wrote a component that adds all group classes to the body. I’m using this for similar cases:
Edit: ah sorry.. you want to change the site setting, not the CSS styling. that’s only the above approach then I guess.
Unfortunately it’s more complicated than that, changing the category page takes more than CSS changes, so that linked method won’t work.
I had a little time and it seemed useful, so I put together a theme component that might cover what you are looking for, called Group categories page override, give it a try!
