Categories on the left, how do I adjust it to the right, you can share css code?
1.categories abnormal(my)
2 categories right
This should right-align them.
table.topic-list td.category { text-align: right; }
thx u
Yeah, that happens when you right align things. Hence why they were originally left aligned.
o add padding-left or padding-right?
Your better option will probably be trying to increase the width of the title column and reduce the category width
You will want to target
/* topic column */
table.topic-list th.default, table.topic-list td.main-link { width: whatever; min-width: whatever; }
/* category column */
table.topic-list th.category, table.topic-list td.category { width: whatever; min-width: whatever; }
