קטגוריות מוצגות כלא מוגדרות
After upgrade, categories show as undefined.
Any suggestion how to debug and change it?
my like is:
Thanks
Looks like Discourse had the same issue.
Ah yes I can see this here on Meta in the category dropdown. It does not show up when no category is selected, but does when a category is selected.
לייק 1
That’s correct.
Thanks.
On second glance, it appears this might be a clear category state. I’ll have a look in the code. The name might be unclear.
PR is baking here: FIX: Category drop shows undefined by justindirose · Pull Request #11090 · discourse/discourse · GitHub
As soon as we have a review, merge, and it goes through CI, you can upgrade to get the fix.
EDIT: Fixed merge and will be available in tests-passed soon.
https://github.com/discourse/discourse/commit/7b312b7bc676528d885fa3f43428c7797958d814
7 לייקים
