It would be useful to implement a theme component (categories: smartphone view) that allows displaying categories as smartphone icons, as shown in the example image below. What do you think?
The discussion revolves around implementing a smartphone-style category view in Discourse, where categories are displayed as icons in a grid format, similar to app icons on a phone. derak proposes a theme component to show categories as smartphone icons, with options to disable descriptions, subcategories, and recent posts, and to customize category names (e.g., âENTâ for âEntertainmentâ). Canapin shares a modified mobile layout using a grid of thumbnails, while Jagster raises concerns about discoverability and clutter. mattdm notes that while jargon may work in niche communities, it may not be intuitive for new users. Heliosurge suggests the feature could be implemented via a theme or plugin, referencing existing thumbnail layouts. Canapin provides CSS tweaks to achieve a minimalist grid layout, removing descriptions and adjusting spacing. hoangphuctran93 appreciates the minimalist design and considers using it for another project.
Hi Cristian, welcome back ![]()
There wouldnât be much space for titles and categoriesâ descriptions which are enabled by default for anonymous and trust level 0 users. A mockup using a âreal worldâ example would be great to see how it would work.
Thatâs not the same but Iâve modified the mobile category page layout on my own forum from:
to:
But I think it could be improved even more with some grid view as you suggest and/or removing the three topics for each category.
OPâs mockup has same issues than smart phones have:
- how to identify and remember what is what, and
- when many is too many.
Hi
It would be sufficient to allow this style (image below) in the smartphone view, with the possibility to disable the category description, the list of subcategories, and the list of latest posts. Then make the list of categories available just like the list of apps on our smartphone (Grid version - squares with rounded corners.).
Another useful feature could be âCustom category name in the smartphone viewâ, so as to shorten the name of a category, from Entertainment to ENT, for example.
This is an example I found on a forum but in a list style.
Why would that work? No one knows what ENT means.
I can see contexts in which this would work â fans of some particular game or niche interest often have their own jargon and even iconography. Would it be the most discoverable and clear to new users? Probably not â but thatâs not always a key value.
Can you share the access link so I can refer them. Or you can check out my site at https://businesslab.vn Iâm happy to share what I know and have done.
also you can refer to the theme page category page Air Theme, I found it similar to what you are looking for.
Iâm simply talking about the navigability of the categories page. Instead of scrolling down to discover the categories, it would be useful to see them all on one page, as described in my first post. Itâs inevitable that in future versions of Discourse, this feature will be implemented, so why not anticipate it?
Yes, as in the last image I posted in the first post, it definitely partially solves the issue.
The theme component is GitHub - discourse/discourse-minimal-category-boxes · GitHub.
Iâm not sure I understand this argument. Why is it inevitable? (And if it is, why rush?)
We kind of have that already with the Customization > Theme grid layout of thumbnails.
So yes is doable of sorts.. Could even have a description pop up maybe if used an idea of short press/long press or single/double tap.
How useable ppl might find it may delend on application. Tbh I find the Customization > Theme topic list annoying on mobile as I find it harder to visually find things.
But of the Op has a more Simplified Category names Icons with Text under them might do Alrighht.
How many Categories are you talking? See my post above and checkout the Customization > Theme link for topic layout with rhumbnails.
Indeed. lol
I can see it being a inevitable that someone will likely create a Customization > Theme component or possibly a Customization > Plugin depending what alm is needed t9 acheive a desired effect.
Weâre aware of that and discussing it ![]()
I was curious, so I made these tweaks to make something like @derak would like:
.category-boxes, .category-boxes-with-topics {
gap: 1em;
.mobile-view .category-boxes .category-box, .mobile-view .category-boxes-with-topics .category-box {
width: 100%;
flex: 0 0 calc(50% - 0.5em);
.category-boxes .description {
display: none;
.category-boxes .category-box .category-box-inner .category-details .category-box-heading h3 {
text-align: center !important;
.category-boxes .category-logo .category-notifications-button, .category-boxes-with-topics .category-logo .category-notifications-button {
visibility: hidden;
.category-boxes .category-box {
box-shadow: 0px 0px 8px rgba(0,0,0,.2);
they look so minimalist, i will consider this version for another project ^^
