Categories with colon cause autocomplete issues
The discussion revolves around an issue with autocomplete in categories containing colons. rriemann initially reported the problem when using the #org:private format, which incorrectly suggests emojis instead of categories. sam suggested simplifying the category name to #org-private to avoid the issue, but acknowledged a legitimate problem with autocomplete. joffreyjaffeux confirmed a fix for not showing the picker at that time, but filtering on subcategories when pressing : would require significant changes. sam proposed not showing the emoji picker if it is directly after a letter, considering it a bigger bug.
Hello,
I have private subcategories with slug “private”. I mention them with #org:private
Unfortunately, when I entered the colon, I get suggestions for emojicons instead of categories (or sub categories).
Have a look here:
Thoughts on this @j.jaffeux?
Hmmm why are you including : in your category name, would it not be much simpler to call it #org-private then there is one less edge case to worry about.
There is a legit issue with the completion though cause test:hamburger: generates test:hamburger: and I incorrectly am getting the autocompleter here.
Yes I have the fix for not showing picker at that time, but filtering on sub categories when pressing : in a string starting with # would be a new feature and would require some non trivial changes to autocomplete.
I would just not worry about showing the emoji picker if it is directly after a letter. That is the bigger bug here.
I tried to remove redundancy in org:org-private in the category name and the path.
“not worry about showing the emoji picker if it is directly after a letter.” :white_check_mark:
