Category Background images retain after being deleted
How to Repo
  1. Insert a category background image (possibile more than 1000px in size)
  2. Save.
  3. Ctrl + F5
  4. Go to the category you added the image and delete it, Click Save. Ctrl + F5 . The background image is still there!
Can you repro this @techapj?
I had to do “hard refresh” to clear category background image (after deleting category image).. Looking more into it.
I sent a PR to fix this issue:
https://github.com/discourse/discourse/pull/4052
I will let @zogstrip review the PR since he is familiar with this code. :slightly_smiling:
Hmm, I actually can’t reproduce this issue. I just tried on try and it worked just fine.
Yes, I am not able to repro this on try too. But I can repro this consistently on my local dev instance.. :confused:
Weird, I can’t even repro this on a regular DO hosted instance.
@Alankrit_Choudh on which instance are you getting this issue? And are you able to repro this consistently?
Well, it lasted for a while, is it possible that this could be happening via Cache from Cloudflare? Happened only once as of now. After that didn’t take the risk of following it on a live production.
I have my instance on DO - https://animeforums.me
Edit i removed the backgrounds from the category. After that, i have not attempted this repro.
