附件中是安装日志
Attached is the installation log
在app.yml 增加了 - “templates/cloudflare.template.yml”
log.txt (167.9 KB)
附件中是安装日志
log.txt (167.9 KB)
[root@iZj ~]# docker info
Client: Docker Engine - Community
Version: 26.0.1
Context: default
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.13.1
Path: /usr/libexec/docker/cli-plugins/docker-buildx
compose: Docker Compose (Docker Inc.)
Version: v2.26.1
Path: /usr/libexec/docker/cli-plugins/docker-compose
Server:
Containers: 5
Running: 0
Paused: 0
Stopped: 5
Images: 5
Server Version: 26.0.1
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Using metacopy: false
Native Overlay Diff: false
userxattr: false
Logging Driver: json-file
Cgroup Driver: cgroupfs
Cgroup Version: 1
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local splunk syslog
Swarm: inactive
Runtimes: io.containerd.runc.v2 runc
Default Runtime: runc
Init Binary: docker-init
containerd version: e377cd56a71523140ca6ae87e30244719194a521
runc version: v1.1.12-0-g51d5e94
init version: de40ad0
Security Options:
seccomp
Profile: builtin
Kernel Version: 5.10.134-16.3.al8.x86_64
Operating System: Alibaba Cloud Linux 3 (Soaring Falcon)
OSType: linux
Architecture: x86_64
CPUs: 2
Total Memory: 3.499GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
[root@iZj ~]# free -m
total used free shared buff/cache available
Mem: 3583 224 2582 2 776 3124
Swap: 0 0 0
[root@iZj~]# df -h
文件系统 容量 已用 可用 已用% 挂载点
devtmpfs 1.8G 0 1.8G 0% /dev
tmpfs 1.8G 0 1.8G 0% /dev/shm
tmpfs 1.8G 540K 1.8G 1% /run
tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup
/dev/vda3 79G 19G 57G 25% /
tmpfs 1.8G 0 1.8G 0% /tmp
/dev/vda2 200M 5.8M 195M 3% /boot/efi
tmpfs 359M 0 359M 0% /run/user/0
The vps is 2 cores, 4 gigs of ram.
I can’t rebuild it, it’s hooked up to cloudflare, and I’m trying to show the real ip.
Added - “templates/cloudflare.template.yml”
I can’t get it to rebuild.
According to your log, the failure was caused by the /tmp/add-cloudflare-ips step, but it’s unclear which specific command within this script failed.
Pups::ExecError: /tmp/add-cloudflare-ips failed with return #<Process::Status: pid 4229 exit 8>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params "/tmp/add-cloudflare-ips"
bootstrap failed with exit code 8
Try removing the Cloudflare line from your app.yml, rebuild, then enter the container and manually execute the commands from templates/cloudflare.template.yml step by step, followed by nginx -s reload. In my experience, network issues causing wget to fail might be the cause.
run:
- file:
path: /tmp/add-cloudflare-ips
chmod: +x
contents: |
#!/bin/bash -e
# Download list of CloudFlare ips
wget -q https://www.cloudflare.com/ips-v4/ -O - > /tmp/cloudflare-ips
echo >> /tmp/cloudflare-ips
wget -q https://www.cloudflare.com/ips-v6/ -O - >> /tmp/cloudflare-ips
# Make into nginx commands and escape for inclusion into sed append command
CONTENTS=$(</tmp/cloudflare-ips sed '/^$/d; s/^.*/set_real_ip_from &;/' | tr '\n' '\\\\' | sed 's/\\\\/\\\\n/g')
echo CloudFlare IPs:
echo $(echo | sed "/^/a $CONTENTS")
# Insert into discourse.conf
sed -i "/sendfile on;/a $CONTENTS\\n" /etc/nginx/conf.d/discourse.conf
#sed -i "/sendfile on;/a $CONTENTS\\nreal_ip_header CF-Connecting-IP;" /etc/nginx/conf.d/discourse.conf
# Clean up
rm /tmp/cloudflare-ips
- exec: "/tmp/add-cloudflare-ips"
- exec: "rm /tmp/add-cloudflare-ips"
Does a VPS need swap? My VPS has a small amount of memory and doesn’t have swap by default.
The reason for your failure has nothing to do with memory/swap.
Also, others have encountered your problem before, so please search before asking. In fact, the Related section below has already intelligently recommended some for you, for example: Failed to bootstrap (/tmp/add-cloudflare-ips)
