https://meta.discourse.org/t/discourse-ip-cloudflare-ip/265556에서 템플릿을 추가하기 위해 앱을 재빌드한 후
https://forum.beginner.center/ 사이트를 운영할 수 없게 되었습니다.
브라우저, 컴퓨터, 서버를 재시작하거나 다른 브라우저를 사용해 보았지만 여전히 작동하지 않습니다.
제 app.yml 파일입니다.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
# - "templates/web.china.template.yml"
## Uncomment the next line to enable the IPv6 listener
#- "templates/web.ipv6.template.yml"
- "templates/web.ssl.template.yml"
- "templates/web.letsencrypt.ssl.template.yml"
# - "templates/cloudflare.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "80:80" # http
- "443:443" # https
- "587:587"
params:
db_shared_buffers: "128MB"
#db_work_mem: "40MB"
#version: tests-passed
env:
LC_ALL: en_US.UTF-8
LANG: en_US.UTF-8
LANGUAGE: en_US.UTF-8
UNICORN_WORKERS: 2
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: forum.beginner.center
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'whitewatercn@outlook.com'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: smtpdm.aliyun.com
DISCOURSE_SMTP_PORT: 80
DISCOURSE_SMTP_USER_NAME: noreply@noreply.beginner.center
DISCOURSE_SMTP_PASSWORD: REDACTED
DISCOURSE_SMTP_ENABLE_START_TLS: false # (optiaonal, default true)
DISCOURSE_SMTP_DOMAIN: noreply.beginner.center
DISCOURSE_NOTIFICATION_EMAIL: noreply@noreply.beginner.center
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
LETSENCRYPT_ACCOUNT_EMAIL: noreply@noreply.beginner.center
## The http or https CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
## The maxmind geolocation IP address key for IP address lookup
## see https://meta.discourse.org/t/-/137387/23 for details
#DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- git clone https://github.com/discourse/discourse-adplugin.git
- git clone https://github.com/paviliondev/discourse-ratings.git
- git clone https://github.com/discourse/discourse-topic-voting
- git clone https://github.com/discourse/discourse-whos-online
- git clone https://github.com/discourse/discourse-solved
- git clone https://github.com/paviliondev/discourse-news
- git clone https://github.com/discourse/discourse-steam-login
- git clone https://github.com/discourse/discourse-table-builder
- git clone https://github.com/merefield/discourse-ai-topic-summary
- git clone https://github.com/discourse/discourse-post-voting
- git clone https://github.com/discourse/discourse-ai
- git clone https://github.com/discourse/discourse-follow
- git clone https://github.com/discourse/discourse-reactions
- git clone https://github.com/discourse/discourse-gamification
- git clone https://github.com/discourse/discourse-yearly-review
- git clone https://github.com/whitewatercn/discourse-embed-bilibili
- git clone https://github.com/discourse/discourse-automation
- git clone https://github.com/discourse/discourse-cakeday
- git clone https://github.com/communiteq/discourse-restrict-pms-to-group
- git clone https://github.com/discourse/discourse-math
run:
- exec: rails r "SiteSetting.notification_email='noreply@noreply.beginner.center'"
./launcher logs app 출력 결과
x86_64 arch detected.
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/01-cleanup-web-pids
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
run-parts: executing /etc/runit/1.d/letsencrypt
[Wed 06 Mar 2024 01:28:00 PM UTC] Domains not changed.
[Wed 06 Mar 2024 01:28:00 PM UTC] Skip, Next renewal time is: 2024-04-11T00:09:12Z
[Wed 06 Mar 2024 01:28:00 PM UTC] Add '--force' to force to renew.
[Wed 06 Mar 2024 01:28:00 PM UTC] Installing key to: /shared/ssl/forum.beginner.center.key
[Wed 06 Mar 2024 01:28:00 PM UTC] Installing full chain to: /shared/ssl/forum.beginner.center.cer
[Wed 06 Mar 2024 01:28:00 PM UTC] Run reload cmd: sv reload nginx
warning: nginx: unable to open supervise/ok: file does not exist
[Wed 06 Mar 2024 01:28:00 PM UTC] Reload error for :
[Wed 06 Mar 2024 01:28:01 PM UTC] Domains not changed.
[Wed 06 Mar 2024 01:28:01 PM UTC] Skip, Next renewal time is: 2024-04-11T00:09:17Z
[Wed 06 Mar 2024 01:28:01 PM UTC] Add '--force' to force to renew.
[Wed 06 Mar 2024 01:28:01 PM UTC] Installing key to: /shared/ssl/forum.beginner.center_ecc.key
[Wed 06 Mar 2024 01:28:01 PM UTC] Installing full chain to: /shared/ssl/forum.beginner.center_ecc.cer
[Wed 06 Mar 2024 01:28:01 PM UTC] Run reload cmd: sv reload nginx
[Wed 06 Mar 2024 01:28:01 PM UTC] Reload error for :
Started runsvdir, PID is 538
ok: run: redis: (pid 547) 0s
ok: run: postgres: (pid 553) 0s
nginx: [warn] the "listen ... http2" directive is deprecated, use the "http2" directive instead in /etc/nginx/conf.d/discourse.conf:60
supervisor pid: 551 unicorn pid: 578
Shutting Down
run-parts: executing /etc/runit/3.d/01-nginx
ok: down: nginx: 0s, normally up
run-parts: executing /etc/runit/3.d/02-unicorn
(551) exiting
ok: down: unicorn: 1s, normally up
run-parts: executing /etc/runit/3.d/10-redis
ok: down: redis: 0s, normally up
run-parts: executing /etc/runit/3.d/99-postgres
ok: down: postgres: 0s, normally up
ok: down: nginx: 3s, normally up
ok: down: postgres: 1s, normally up
ok: down: redis: 2s, normally up
ok: down: cron: 0s, normally up
ok: down: unicorn: 3s, normally up
ok: down: rsyslog: 0s, normally up
[Wed 06 Mar 2024 01:51:54 PM UTC] Domains not changed.
[Wed 06 Mar 2024 01:51:54 PM UTC] Skip, Next renewal time is: 2024-04-11T00:09:12Z
[Wed 06 Mar 2024 01:51:54 PM UTC] Add '--force' to force to renew.
[Wed 06 Mar 2024 01:51:54 PM UTC] Installing key to: /shared/ssl/forum.beginner.center.key
[Wed 06 Mar 2024 01:51:54 PM UTC] Installing full chain to: /shared/ssl/forum.beginner.center.cer
[Wed 06 Mar 2024 01:51:54 PM UTC] Run reload cmd: sv reload nginx
fail: nginx: runsv not running
[Wed 06 Mar 2024 01:51:54 PM UTC] Reload error for :
[Wed 06 Mar 2024 01:51:54 PM UTC] Skip, Next renewal time is: 2024-04-11T00:09:17Z
[Wed 06 Mar 2024 01:51:55 PM UTC] Installing key to: /shared/ssl/forum.beginner.center_ecc.key
[Wed 06 Mar 2024 01:51:55 PM UTC] Installing full chain to: /shared/ssl/forum.beginner.center_ecc.cer
[Wed 06 Mar 2024 01:51:55 PM UTC] Run reload cmd: sv reload nginx
[Wed 06 Mar 2024 01:51:55 PM UTC] Reload error for :
Started runsvdir, PID is 531
ok: run: redis: (pid 543) 0s
ok: run: postgres: (pid 548) 0s
supervisor pid: 541 unicorn pid: 571
