This would be a nice feature. At the moment I think it’s based on the date the forum was added. Otherwise I can’t think of anything to change. Thanks.
This is already supported in the app, you can long-press a site in the home screen and drag it up or down, that should change the order the sites are in.
Thanks. This works fine. I’d tried it before - maybe it takes a split second longer than most apps to feedback that the long-press is having an effect.
