I think there is something that the site admins have to do if necessary. I think it is not possible to automatically change language strings to use reaction instead like if the reaction plugin is active. So I think the problem is also occur if the reaction plugin is in core because the forum admin will decide to use it or not.
Probably the solution is simply rename the like to reaction by default. Because is a reaction and this can work no matter if a forum use Discourse Reactions or not.
If there is necessary the icon in notifications, topic list item likes can be change with discourse-emojis icon if the Discourse Reactions enabled. This could be a setting in the plugin.
I was referring to how the reaction showed up (which I expected), and then a like also showed up (which was unexpected)
I mean they’re not registering that way at all in my notification log for likes/reactions, likes are the only ones that are visible there. Both can be seen normally here:
I still don’t understand. It would help if you could provide more specific written replication steps or annotate your screenshots otherwise it is hard to follow. Don’t think anything is happening here that is not by design?
Clearly written replication steps would be immensely helpful. Also more specifics like what page (specific url) are you on when you see what you are not expecting to see? Without replication steps it is not going to be possible for us to pin down problems you are describing and decide what if anything we want to do about it.
Vaguely, I am thinking you are referring to the notifications page on your user profile. It’s possible that you are seeing a bug with how likes and other reactions are displayed on the “Likes” and “Reactions” sub-page there. I know that on the notification menu we “roll up” reactions and likes into e.g. “@user reacted to 5 of your posts” to not add clutter.
Just got reactions, and happened to check my notifications on the page rather than the notification menu.
Regardless, the other forums I could originally see this on, I cannot do so anymore, so… Perhaps a cache issue or version differences by a few commits?
Reading between the lines and squinting a little (or alot) I was actually able to replicate the problem you are describing. Go to https://meta.discourse.org/u/Firepup650/notifications/reactions-received?include_likes=true and you will see the reactions and likes on the same page and there you also will see that one post is listed twice, once with a reaction and once with a heart. See my screenshot below.
This happpens when you have ?include_likes=true appended to the URL, which happens when you click on a “rolled up notification” as I explained two posts up.
I agree this is a bug and likely we should do something about it but it’s not urgent.
Ah I see, I missed this case. But yes this is a bug and needs to be fixed – we had a similar bug where reaction-likes were showing on the /notifications/likes-received URL. I will do a fix, thanks for bearing with us @Firepup650!
So has this been implemented in a beta release as yet? (I’m on a third party hosting provider who maintain the Discourse instance for me and keep it up to date with each beta release). My version of Discourse doesn’t seem to behaving in this way yet!
The change is in the discourse-reactions plugin, so it’s not tied to core’s release schedule. Technically it was added in this commit of the plugin on 13th February. So, if you (or your hosting provider) have updated the plugin since then, you will have the change.
You can verify by looking in your site settings for the new ‘discourse reactions excluded from like’ setting. If that setting exists, then you have the new behaviour.
We use the gamification plugin (/admin/plugins/gamification).
Should we recalculate all scores given this change? I’m considering doing that for “all time” so that it treats all reactions (except those on the discourse_reactions_excluded_from_like list) as a like.
