Alterar o flair do grupo para combinar com o tema atual
Hi, I was making a verified status group for my site and it is styled to be a dark grey circle with a white ‘checkmark’ inside. This fits well with the default light Discourse theme. However, if I switched my theme to the dark one then the flair’s edges may blend with the outer dark theme? Am I right and if so how can I fix this?
You can use the color-scheme variables in CSS to make the flair work with any color scheme. Try something like this:
.avatar-flair-verified {
  background: $primary !important;
  i {
    color: $secondary !important;
Where verified in .avatar-flair-verified is the name of the group you’re targeting.
I used !important because you’re overriding inline styles. The result is something like this:
You can read more theme variables here:
How to use Discourse core variables in your theme
4 curtidas
