Changing the language of my discourse instance after initial install
I’m on a pro hosted instance and it was initially installed in English. Although the interface language setting works great (and the default is to French), the text content & email templates are in English. As far as I know these are not translated depending on the user lang. So I’d like to switch them to French.
  • Is there a better way than CTRL-C from the i18n source to my discourse admin ?
  • If no, I cannot to find system_messages.usage_tips.text_body_template in French anywhere, does it mean it does not exist ?
Thanks for your help !
Unfortunately no.
Seems like it hasn’t been translated yet :frowning:
https://www.transifex.com/discourse/discourse-org/translate/#fr_FR/serverenyml/13698675?key=usage_tips
Fair enough ! I’ll be translating it for all then, extra careful mode on :wink:
And CTRL-V it is !
Thanks :heart:
