在 Ubuntu 22.04 上使用 标准安装 进行的干净安装一直失败。
我看到了这些错误,但不知道需要检查什么来解决它(我是 Discourse 新手)。
I, [2024-02-12T06:24:53.611992 #1] INFO -- : cd /var/www/discourse & su discourse -c 'bundle exec rake themes:update assets:precompile'
Node.js heap_size_limit (1956.0) is less than 2048MB. Setting --max-old-space-size=2048.
Purging temp files
Bundling assets
#<Thread:0x00007f53d0e37ff8 /var/www/discourse/lib/tasks/maxminddb.rake:62 run> terminated with exception (report_on_exception is true):
/var/www/discourse/lib/discourse_ip_info.rb:48:in `mmdb_download': undefined method `path' for nil:NilClass (NoMethodError)
filename = File.basename(gz_file.path)
from /var/www/discourse/lib/tasks/maxminddb.rake:67:in `block (3 levels) in <main>'
from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `each'
from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `block (2 levels) in <main>'
Done compiling CSS: 2024-02-12 06:27:28 UTC
I, [2024-02-12T06:27:28.245776 #1] INFO -- : yarn run v1.22.19
$ /var/www/discourse/app/assets/javascripts/node_modules/.bin/ember build
最后是这个
Done in 122.74s.
Downloading MaxMindDB...
Compressing Javascript and Generating Source Maps
I, [2024-02-12T06:27:28.246766 #1] INFO -- : Terminating async processes
I, [2024-02-12T06:27:28.246802 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 57
I, [2024-02-12T06:27:28.246832 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 126
2024-02-12 06:27:28.246 UTC [57] LOG: received fast shutdown request
126:signal-handler (1707719248) Received SIGTERM scheduling shutdown...
2024-02-12 06:27:28.248 UTC [57] LOG: aborting any active transactions
2024-02-12 06:27:28.250 UTC [57] LOG: background worker "logical replication launcher" (PID 66) exited with exit code 1
2024-02-12 06:27:28.251 UTC [61] LOG: shutting down
126:M 12 Feb 2024 06:27:28.258 # User requested shutdown...
126:M 12 Feb 2024 06:27:28.258 * Saving the final RDB snapshot before exiting.
126:M 12 Feb 2024 06:27:28.263 * DB saved on disk
126:M 12 Feb 2024 06:27:28.263 # Redis is now ready to exit, bye bye...
2024-02-12 06:27:28.409 UTC [57] LOG: database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse & su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3428 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
我错过了什么?
