sudoman
(Andrew E)
10 Settembre 2018, 8:56pm
1
Hello Discourse,
Is there a preexisting code base out there for pushing emails to Discourse’s incoming email API?
Thanks,
Andrew
blake
(Blake Erickson)
10 Settembre 2018, 11:29pm
From the output of rake routes You can send a POST request to
admin/email/handle_mail
Here is the controller method from handle_mail:
# frozen_string_literal: true
class Admin::EmailController < Admin::AdminController
def index
def server_settings
data = { delivery_method: delivery_method, settings: delivery_settings }
render_json_dump(data)
def test
params.require(:email_address)
begin
message = TestMailer.send_test(params[:email_address])
Email::Sender.new(message, :test_message).send
render json: { sent_test_email_message: I18n.t("admin.email.sent_test") }
rescue => e
render json: { errors: [e.message] }, status: :unprocessable_entity
def preview_digest
params.require(:last_seen_at)
params.require(:username)
user = User.find_by_username(params[:username])
raise Discourse::InvalidParameters unless user
renderer = Email::Renderer.new(UserNotifications.digest(user, since: params[:last_seen_at]))
render json: MultiJson.dump(html_content: renderer.html, text_content: renderer.text)
def advanced_test
params.require(:email)
receiver = Email::Receiver.new(params["email"])
text, elided, format = receiver.select_body
render json: success_json.merge!(text: text, elided: elided, format: format)
def send_digest
message, skip_reason =
UserNotifications.public_send(
:digest,
user,
since: params[:last_seen_at],
skip_unsubscribe_links: true,
if message
message.to = params[:email]
begin
Email::Sender.new(message, :digest).send
rescue => e
else
render json: { errors: skip_reason }
# TODO (martin) Remove this in 3.7.0, this endpoint has been broken for years
# and was used only in the public mail-receiver's fast rejection code,
# which is removed in https://github.com/discourse/mail-receiver/pull/33
def smtp_should_reject
render json: { reject: false }
def handle_mail
deprecated_email_param_used = false
if params[:email_encoded].present?
email_raw = Base64.strict_decode64(params[:email_encoded])
elsif params[:email].present?
deprecated_email_param_used = true
email_raw = params[:email]
else
raise ActionController::ParameterMissing.new("email_encoded or email")
# If it isn't valid UTF-8, reinterpret as ISO-8859-1 so it can be serialized to JSON.
email_raw = email_raw.dup.force_encoding("UTF-8")
email_raw = email_raw.encode("UTF-8", "ISO-8859-1") if !email_raw.valid_encoding?
Jobs.enqueue(:process_email, mail: email_raw, retry_on_rate_limit: true, source: "handle_mail")
if deprecated_email_param_used
warning =
"warning: the email parameter is deprecated. all POST requests to this route should be sent with a base64 strict encoded email_encoded parameter instead. email has been received and is queued for processing"
Discourse.deprecate(warning, drop_from: "3.3.0")
render plain: warning
else
render plain: "email has been received and is queued for processing"
private
def delivery_settings
action_mailer_settings.reject { |k, _| k == :password }.map { |k, v| { name: k, value: v } }
def delivery_method
ActionMailer::Base.delivery_method
def action_mailer_settings
ActionMailer::Base.public_send "#{delivery_method}_settings"
Per un utente non tecnico, avrei bisogno di comprendere le funzionalità della posta in arrivo tramite API:
Cosa ho già fatto:
Ricezione di email tramite polling POP3 sul dominio principale (non su un sottodominio)
Funzionamento della ricezione di email tramite il modulo mail di Postfix, ma questo funziona solo per i sottodomini – nel mio caso, xxx@community.eleoptics.com – che non possiamo utilizzare; è necessario il dominio principale.
Configurazione attuale:
Email in arrivo: indirizzo email di “Gruppi” di G Suite di Google che inoltra verso account Gmail gratuiti (per evitare di pagare un account G Suite per ogni indirizzo email). Polling POP3.
Email in uscita: inoltra tramite relay SMTP validato dall’indirizzo IP della mia installazione di Discourse su Google Cloud.
Questo funziona, ma gli account gratuiti per il polling POP3 di Gmail sono qualcosa da cui vorrei liberarmi.
Pianifichiamo di utilizzare l’API Email di Google Cloud Platform per gestire le email in entrata e in uscita, idealmente per un’implementazione e un servizio su larga scala.
Dove posso trovare la documentazione da inviare ai miei collaboratori tecnici su come configurare la ricezione diretta delle email su Discourse?
Se è già collegata nel post sopra, grazie. Altrimenti, immagino che serva una spiegazione più contestualizzata.
blake:
Ecco il metodo del controller da handle_mail:
github.com
message, skip_reason = UserNotifications.public_send(:digest, user,
if message
begin
rescue => e
render json: { errors: [e.message] }, status: 422
else
