Commits per release
I’m looking to incrementally update a site since going from 2.4.0beta11 to 2.6.0.beta2 failed on my site.
I did git tag and got no results.
Is there a map of commit id’s that marry to each beta release?
Cheers and thanks!
You can use the name of the beta release itself.
I’m afraid that will not be any different then. It’s better to try to solve the actual problem you’re running into.
