I don’t know if it’s a bug, but the confirmation field type in the User Field doesn’t show the Field Name in the modal view, only the description or checkbox.
A discussion about the Confirmation Field Type in User Fields not showing the Field Name in the interface. chi initially reported this as a potential bug, but after clarification from jomaxro, they realized it might not be the intended functionality. However, when jomaxro encountered a similar issue with a customer, they reclassified it as a bug, citing inconsistencies with other field types. neil has since added a label and fixed the padding around the confirm checkbox row, providing a visual update.
I don’t believe it is a bug, but how would you expect it to work? At the moment the Field Name is not used, and the description appears next to the box. How would you want the confirmation field to appear?
I was thinking that it would act like a checkbox with multiple options. Where we can list down all the possible options available and check which items apply to them.
The Field Name - Acts like the Question or Title of the Checkbox, while description will be details of the checkbox.
But I think that is not the purpose of the checkbox there. ![]()
Thanks for clearing this out.
Well, this just came with a customer - and now I understand the issue @chi reported. I would classify this as a bug - both other field types display both the Field Name and the description, the checkbox should do the same.
This topic was automatically closed after 32 hours. New replies are no longer allowed.
