Contains_dtoc in Grey Amber theme header
If you switch to Grey Amber theme here you can see a “contains_dtoc” in the header.
Not sure what category this belongs in (here or bug).
6 לייקים
Looks like an issue with the DiscoTOC theme component (cc @Johani). This is specific to Meta and I’ve removed the component for now (it was only enabled on some themes).
6 לייקים
What’s the best way to go about disabling this component if it this breaks all my theme views preventing me pulling up mainsite or /admin?
לייק 1
Access your site via safe mode. Go to forum.example.com/safe-mode, disable the current theme, and then you can disable the theme component from the admin panel. See Using Safe Mode to troubleshoot issues with themes and plugins for more details.
3 לייקים
It appears this has been fixed for my issue. Updated dtoc via safe mode and now works. I think I got an update between code pushes. Thanks
this is not just a grey amber theme issue - I had the same problem with the regular light and dark themes.
In any case, safe mode, update the table of contents theme component worked to bring my site back.
4 לייקים
The root cause is fixed. See
https://meta.discourse.org/t/discotoc-automatic-table-of-contents/111143/82?u=johani
Thanks for reporting the issue @Ellibereth :+1:
7 לייקים
