Crazy in Love badge description not reflecting max_likes_per_day setting
סיכום מבוסס בינה מלאכותית
A user, rkda, discovered an issue with the Crazy in Love badge description not reflecting the max_likes_per_day setting. The short description is hard-coded to 50 likes, despite the community’s setting being raised to 150. rkda created a PR to fix this issue (https://github.com/discourse/discourse/pull/9741).
rkda initially thought that other locales would inherit from the en locale, but found that they had been translated separately, also containing the error. Falco clarified that fixing the en locale first is sufficient, as the translations will be updated automatically after the PR is merged.
Noticed this on one of the communities I’m active on. They raised the maximum daily likes value to 150. This is reflected on all the badge descriptions save for the Crazy in Love badge. The short description still says 50 likes. The long description doesn’t have this error.
Checked the source code and 50 is hard-coded on the Crazy in Love description so I made a PR.
I naively thought that all the other locales just inherit from the en locale. Just realized that those were translated so the error can be found on other locales as well. Is there a single source I should fix first? Or is it fine to go ahead and fix all instances of this error on the other locales?
3 לייקים
The other locales will be updated after your PR is merged, the en locale goes to the translation service, it gets translated, and then synced back into Discourse.
4 לייקים
Got it. Thanks for the clarification!
