Achievement 500 likes
סיכום מבוסס בינה מלאכותית
The Achievement 500 likes has been causing confusion due to a bad translation. Yu_Gong1 initially thought it was about getting 500 likes in a single day, but codinghorror clarified that it’s likely referring to 500 lifetime likes. However, after further investigation by Falco, it was discovered that the badge ID 33 is actually for the Out of Love badge, which is awarded when you’ve liked 50 posts on the same day, not 500. zogstrip confirmed this, but was later corrected by ClawdiaWolf that the badge is actually based on the max likes per day setting, which is a variable in the English descriptions.
Anyone realized that this achievement (Ahievement 500 likes) works really weird? People who say they never liked 500 things in a single day also achieved this? :smiley:
or is it just a bad translation and the validation is not really 500 likes a day?:smiley:
לייק 1
Can you clarify which badge you’re referring to? I’d expect it is 500 lifetime not 500 in a single day.
4 לייקים
its ID seems to be 33
2 לייקים
That may as well be a bad translation. The badge 33 in Meta, is Discourse Meta and that is not about 500 likes.
4 לייקים
Looks like a typo in the translation.
The Out of Love badge is awarded when you’ve liked 50 posts on the same day.
4 לייקים
It seems that i cant edit these translations. Any idea is it possbile to edit description some how? :slight_smile:
2 לייקים
I was under the impression it was based on the max likes per day setting, and the English versions of the descriptions use the %{max_likes_per_day} variable in both the short and long descriptions.
4 לייקים
That’s 100% correct @ClawdiaWolf.
I stand corrected :+1:
3 לייקים
