Does increasing the limit for daily badges have implications for badges?
I’ve had an unexplained claim that ”increasing the daily limit will effect some badges"
Can anyone corroborate/ explain/ debunk this
TIA
TIA
Without asking you to be more specific about this, I assume you mean the “out of love” badge and the max likes per day
setting? nothing breaks. the badge is hardcoded to the setting. if you change setting (default is 50), the badge criteria changes.
the best way to change likes limits is via trust level like multipliers.
Thanks you Lily
You’ve confirmed everything I thought and not introduced any additional concerns
You’ve also suggested the way to adjust as I had thought was appropriate
Basically a community is being lied to be ours admin
