Create new tabs in Emoji selector
The discussion revolves around adding new tabs to the emoji selector in Discourse, particularly for organizing custom emojis like flags. Steven initially asked if it’s possible to create a dedicated category for emojis, such as a ‘flags’ tab between the ‘#’ and ‘poop’ categories, to improve organization. codinghorror confirmed it’s not currently possible. sam pointed to the relevant code in the emoji toolbar, and Steven shared a plugin solution for custom emoji ordering. bartv later asked if a new tab could be added via the existing emoji browser, and bartv discovered that after adding custom emojis in the admin panel and rebuilding the app, a new tab appears automatically, using the first custom emoji as the icon. Jennifer_Abrams asked if custom emojis can appear first when opening the selector. Steven updated the thread, noting that since May 2020, this is possible via the /admin/customize/emojis page, and recommended a plugin for better control: iunctis-emojis.
Hello everyone,
I’dl like to know if it’s possible to add a category for the emojis. Like you did with smiley face, dog, house, #.
For my forum, I’d like to add some flags but they’re mixed with other uploaded emojis in the poop category, and it’s not great for my OCD :stuck_out_tongue:
It would be a flag category between the # and the poop category for example.
I know how to ssh the app, and how to create a plugin with github, so if i have a lead, i won’t bother you a lot.
Thanks !
There is no way to do this at the current time.
Ok, thanks for the reply !
It’s actually exported (albeit not using ES6 which we should move it to)
Thanks, I’ll look into it !
@Steven did you ever figure out how to add a new tab to the emoji browser? I have a case for that as well.
I didn’t really know how to do this at the time and I went another direction with this plugin : https://github.com/discourse/discourse-emoji
You can add custom emojis and choose in what order they will appear. It was good enough for my needs
Thanks Steven! I’d rather use the existing dialog, so I’ll dig a little further.
For future reference (and after my first visit to the Discourse source code ;-): after adding custom emojis in the admin, just rebuild the app. A custom tab will then be added to the emoji picker and the first custom emoji you created will be used as the tab icon:
Так что есть ли способ сделать так, чтобы пользовательские эмодзи отображались первыми? Например, сразу при открытии селектора?
Эта тема была поднята, поэтому я дам всем небольшое обновление. Это можно сделать с мая 2020 года
Мы можем сделать это на странице /admin/customize/emojis
Я предпочитаю использовать плагин для решения всех вопросов, и он работает отлично: GitHub - MonDiscourse/iunctis-emojis · GitHub
