I am horrible at finding the right Emoji that properly expresses what I mean using the traditional hunt-and-peck model.
The secondary, go-to-other-index-website-model also does not work great for me, I have way too many windows and tabs open.
What would be cool would be some sort of Emoji toolbar widget…
It could allow me to pick an Emoji, gangnam Apple style:
work in progress: not finished yet, but you get the idea
My plan is to add pagination and sections, groups are already defined, 50 emojis per page seems reasonable, any more and you are both flooded with info and http requests.
I like this but would it be possible to turn it off in the admin settings until the functionality settles?
Also, as I wrote elsewhere, I see there’s a new emoji popup in the editor, but I got confused by it at first - it can’t be closed once opened except by choosing an emoji or clicking in the greyed out area outside the emoji selector. Hitting ESC minimizes your post and there is no X available to close it.
Still, should be more tabs – ala the Slack model. Better to be wide (widescreen) than tall. Particularly because our editor default is so very wide with preview side-by-side.
And none of the toolbar stuff is visible on mobile, deservedly so.
@sam I really like your work on the emoji picker toolbar item - nicely done! I can already tell this is going to be a well loved feature.
… that said, I am not keen on the emoji and am wishing it were not featured so prominently… esp as I am now launching a forum including people in Sierra Leone who are grappling with ebola. Just conjures up unnecessarily negative images. Can this list be admin editable?
Or can the emoji toolbar item be disabled while it is still experimental?
Ahh, the Ctrl+E shortcut is freaking me out miserably. Even in the five seconds it has taken me to come here and complain, I accidentally just opened it twice in the process of trying to write the first sentence of this post. Ctrl+E goes to end of line on Mac (and Emacs), the opposite of Ctrl+A. I hit it all the time, so linking it to the emoji popup is rather – ah, jarring is the word (I just did it again).
Can we use another shortcut, or disable the shortcut and just show the toolbar item, or have a way to disable the shortcut without disabling the emoji plugin? (If it’s just me, I’m fine just disabling the plugin; not sure how many others use the shortcut, but it seems pretty basic to me.)
