Creating form templates
:bookmark: This guide explains how to use form templates for structuring content in Discourse.
:person_raising_hand: Required user level: Administrator
Form templates let you create structured forms with validation rules that users can fill out when creating topics so you can ensure users provide all the information you want or need to support them, such as for bug reports, feature requests, etc.
Note: For templates that function more like guidelines instead of a structured form, consider using topic templates.
Enabling form templates
You can turn on form templates in Upcoming changes by setting Enable form templates to “Everyone”.
You can create and manage form templates by going to Admin > Appearance > Form templates (/admin/customize/form-templates).
To create a form template:
  1. Click New Template.
  1. Update the Template Name field with an internal name for your template.
  2. Use the buttons at the top of the page to the various fields on your form and update the field attributes (detailed below). Many of the options are standard form field types (e.g., checkbox, short answer, dropdown, etc.), but there are a few specific fields:
    • Tag Group selector: Users can select one or more tags from a particular group.
    • Markdown answer: Users can add content directly into a mini-version of the composer. This is ideal for when members need to input Markdown directly, such as code, or need other formatting supported by the rich editor.
  3. Add any desired validations to your inputs. Click the Validation button for a key (also displayed below).
  4. Click the Preview button to make sure everything looks right.
  5. Click Save.
Field attributes
Common attributes for all field types:
  • label: The visible field name
  • placeholder: Helper text shown in empty fields (input, textarea, dropdown, multi-select)
  • description: Additional context or instructions displayed below the field.
Upload-specific attributes:
  • file_types: Comma-separated list of allowed file extensions (e.g., .jpg, .png, .pdf)
  • allow_multiple: Boolean indicating whether users can upload multiple files
Dropdown and multi-select attributes:
  • none_label: Text shown when no option is selected
  • choices: Array of available options
Tag Group selector attributes:
  • tag_group: (top-level field property) The name of the tag group to populate choices from
  • multiple: Boolean indicating whether users can select multiple tags (default scaffold sets this to true)
Validation options
Key Type Description
required boolean Requires the field to be completed to submit the form.
minimum integer For text fields, specifies the minimum number of characters allowed.
maximum integer For text fields, specifies the maximum number of characters allowed.
pattern regex; string For text fields, a regular expression specifying the allowed input.
type string For input fields, you can specify the type of input that should be expected (text, email, date, number, url, tel, color, password)
Adding form templates to a category
After creating a template:
  1. Navigate to the category where you want to use the template.
  2. Click the :wrench: button to edit the category.
  1. Toggle the Advanced settings button (if using the new simplified category design).
  2. Go to the Template tab.
  3. Turn on the Form template toggle.
  4. Select the form template in the drop-down menu.
  5. Click Save category.
When multiple templates are assigned to a category, users will see a template picker when creating topics.
Member Experience
Creating topics with form templates
When a member creates a topic in a category with form templates, the form automatically appears in the composer. If multiple templates are applied to the same category, members can choose the right template from a drop-down. If users try to create a topic without accurately populating each field, they’ll see a validation error.
Pre-filling form values
Form fields can be pre-populated using URL parameters that match field IDs. For example: /new-topic?software-version=2.4.1&severity=Critical
This is useful for linking to topic creation with certain fields already filled.
What do the regex patterns look like and what flavour of regex is expected? I tried the following and they all passed, but I wasn’t expecting them to:
  • 2[6-9][0-1][0-9][0-3][0-9] with an entry of 180918;
  • /2[6-9][0-1][0-9][0-3][0-9]/ with an entry of 180918;
  • /2[6-9][0-1][0-9][0-3][0-9]/ with an entry of 12;
10 posts were split to a new topic: Adding paste functionality to form composer fields
