自定义管理员工具箱
A simple theme component to support admin task-flow when setting up or working on an instance.
This is basically just a fork of the Custom header links (icons) theme component. I changed the preset icons to a few one-click links to admin pages (Settings, Customize, Text):
Screenshot from 2021-09-30 11-49-09
Also added a few settings: You can limit the display of the icons to one specific admin user. And you can toggle the display of various alert banners.
If you use this component and come across banners that aren’t hidden, let me know :slight_smile:
11 个赞
是否可以将工具箱提供给管理员/员工或版主等群组?
默认情况下,它仅对管理员显示。另一个组的用例是什么?
已标记为end-of-life,因为现在有了一个功能强大的官方组件:
2 个赞
