Continuing the discussion from Adding and editing user custom fields :
Note that there can be other custom fields added by plugins, and they might have a strict structure, which I think is why this hasn’t been done. For the “private notes on a user” plugin, it wouldn’t exactly do to expose your ‘private’ notes to the moderators when they went to a user’s page.
Would these fields even show up on user / admin pages I would have assumed it would only be the user_field_X which are added via the site/customize…
I ask, because I’ve created a field called “subdomain” in the database directly, and it’s no where to be seen in the GUI (which is as I expect)
Never, unless the plugin also adds UI for it.
Good. So this isn’t a factor in what I’m whining asking for here
tgxworld
(Alan Tan)
24 أغسطس 2015، 6:54ص
4
I ran into this problem and wasn’t sure if there was a better way to expose it under User’s preferences.
public_user_custom_fields_setting = SiteSetting.public_user_custom_fields
if public_user_custom_fields_setting.empty?
SiteSetting.set("public_user_custom_fields", "date_of_birth")
elsif public_user_custom_fields_setting !~ /date_of_birth/
SiteSetting.set(
[SiteSetting.public_user_custom_fields, "date_of_birth"].join("|")
class ::UserSerializer
alias_method :_custom_fields, :custom_fields
def custom_fields
if !object.custom_fields["date_of_birth"]
object.custom_fields["date_of_birth"] = ""
object.save
_custom_fields
Any thoughts?
tgxworld
(Alan Tan)
27 أغسطس 2015، 2:07ص
5
@sam Could I get your thoughts on the above? Thanks
sam
(Sam Saffron)
1 مارس 2017، 2:32م
6
Well … any update on what ended up happening here
tgxworld
(Alan Tan)
3 أبريل 2017، 2:13ص
7
I ended up using a plugin outlet here. From what I know, we still don’t have a clean way for plugins to expose custom fields on the user preferences page.
I’m trying to do the same … what would be a cleaner way?
