Benutzerdefinierte Felder über Plugin Outlet hinzufügen
In my custom theme, I am attempting to create custom user fields using the plugin-outlet at preferences/profile and I am part way there.
I have successfully inserted new custom fields into User Preferences, but the information I entered into the UI does not stick after clicking save.
For example, I created this checkbox like this:
       <script type="text/x-handlebars" data-template-name="preferences/profile"> [all the other code]
<div class="control-group pref-check1">
  <label class="control-label">I like beer</label>
  <div class="controls">
    {{input type="checkbox" name="check1" value="true" class="input-xxlarge"}}
  </div>
</div>
</script>
What do I need to do to save the info entered in the preferences UI (and then display it in the /user template)? Is this possible with a custom theme?
Why am I doing this?
I am aware that you can create custom user fields under settings. I have a 3-4 different types of user custom fields for which I want finer control over the visual display on the user profile. For example some fields are text and some are true/false.
Since all custom user fields have the same class this is difficult. And I find :nth-child() a pain.
So my goal is to insert them into the template and control their classes and display.
I am interested in guidance specific to my first question and to my larger goal.
Cheers
Update. I ended up accomplishing my end goal with CSS without too much pain.
I realize that creating custom fields outside of the UI provided is more complicated than what I described above. I would be interested in eventually learning how to do this if anyone can point me to the right resources.
Having a great time learning how to develop Discourse!
Thanks!
Discourse Cakeday adds some custom fields to the user profile.
https://github.com/discourse/discourse-cakeday
Probably the best way to approach this is find where those custom fields are added in the code (both the Ember front-end and the Rails back-end).
Cool , will check it out. Many thanks !
Wo wird das Feld erstellt?
(plugin für mich selbst neu geschrieben)
