Custom menu with an AJAX call
Hello,
I set up a forum and I would like to have the same menu as the site on the forum. So for that, I have a route that returns the menu.
I see two solutions: make an ajax call and append the result in the dom or create a plugin to customize the header.
The first solution is easy to set up but I would like to know how to create a plugin with an ajax call.
I managed to create the widget but I did’nt succed to make an ajax call .
Is that possible ?
Thanks,
Happy
The best way to get help is to show code :wink:
You’re right :slight_smile:
Here’s the code I have a mistake with.
export default createWidget('discourse-custom-header', {
    tagName: 'div',
    html() {
        return $.when($.ajax({
            url: 'http://www.example.com/menu',
            async: false
        })).then(result => {
            return [
                h('div', [
                    new RawHtml({ html: `${result}` })
I get this warning
[Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check https://xhr.spec.whatwg.org/.
and this error
Error: Unexpected virtual child passed to h().
Expected a VNode / Vthunk / VWidget / string but:
got:
The parent vnode is:
    "tagName": "DIV",
    "properties": {
        "attributes": {},
        "className": "custom-menu"
Why isn’t it async: true?
Even with the async option to true, i have the same error. I don’t think the async option is the real problem here, but maybe i’m wrong.
