I’ve found the PM text for TL1 (system_messages.welcome_tl1_user.text_body_template) and TL2 (system_messages.tl2_promotion_message.text_body_template), but can’t find the equivalent for TL3. What is it? Thanks.
The discussion revolves around customizing the text for TL3 promotion private messages (PMs). Jonathan5 initially sought the template for TL3 promotion PMs but was informed by twofoursixeight that no default TL3 promotion PM exists. However, JammyDodger suggested using the Automation plugin to set up a custom PM with a ‘Send PMs’ script and ‘User Promoted’ trigger. Jonathan5 expressed hesitation due to not already using the plugin, but JammyDodger assured that it is easy to set up and offers many useful features.
There is no TL3 promotion PM, last time I checked. I got TL3 promotion several times and never got a PM from the forum
I think you can set one up with the Automation plugin though using the ‘Send PMs’ script with a ‘User Promoted’ trigger:
Thanks. I can see why there might not be one for demotion but I’d always thought there was one for promotion. Having said that, it was a surprise when I first noticed I could edit the title of someone else’s post, so maybe there was no warning…
I’ll look into that but it seems like a disproportionate amount of effort, as I’m not already using that plugin.
FWIW It’s actually really easy once it’s installed (and the plugin has lots of other useful features too once you get into it). It’s basically the dropdowns in the screenshot + writing the message itself, and it should JustWork™.
