La personalización en la etiqueta body no aparecerá en algunas páginas
If I add some customization in body tag like a div as shown in below screenshot:
The div appears in normal pages, but it won’t appear in some pages like (topic not found) page: for example
https://meta.discourse.org/t/123456778888888
While other customization works as expected that is added via head Header Footer etc.
2 Me gusta
This is somewhat tricky
I can spot two issues here …
  1. footer is not in footer tag. Which may be very tricky to fix if static pages add footer already.
  2. We are missing <%= raw theme_lookup("body_tag") %>
(2) is probably very simple and safe to add… (1) is hard.
@Johani can you add this to your list to determine if (2) is safe and just do a PR for it.
5 Me gusta
Ahora buscamos los campos del tema de manera más consistente en todas las vistas relevantes.
Gracias por reportar el problema @leo.proctor :+1:
4 Me gusta
