カスタムハンバーガーメニューでテーマ切り替えと事前定義フィルターの適用を追加
Continuing the discussion from Different themes per category?:
Hello,
Can I add an entry in the hamburger menu what switches to predefined filter and activates the Kanban Board Theme Component (or any other of the those lsited below)
In addition, is shall make visible
in the navigation bar.
Duplicate your current theme, enable/add those components to the new one, give it a name.
Next, install the Hamburger theme selector and them to both themes. Let me know how it goes :slight_smile:
means I merge the current one with the Kanban Board Theme Component?
If you only want the new theme to have Kanban boards, then add that component to the duplicated theme only.
slowly getting it thx :blush:
are there options to customize the hamburger menu besides of addin the theme selector?
as far as I remember navigation bar can be customized but cannot find the how.to anymore.
方法は、最新のDiscourseインストールで利用可能な「カスタムセクションの追加」機能です。:slight_smile:
詳細はこちらをご覧ください: Custom sidebar sections being tested on meta
